American DJ AccuSpot 250 II 9-Channel Mode
Hambone
Band Member
I Use FreeStyler for: Band
Post by Hambone »
Here is a completely tested and functional fixture file for the ADJ AccuSpot 250 II in 9 channel mode. It has lots of macros for gobo shake and rotation, shutter strobe, and shutter pulse. Note that in order for the half-colors to work, you must have the lamp channel (channel 8) set to 20. If it's set to 0, the fixture will only go to solid colors.
Also, because I like to keep all my custom fixtures organized in my system and rule out the possibility of it being overwritten during an upgrade, the manufacturer is Two For Flinching. You can change this in the Fixture Creator if you want to :)
ADJ AccuSpot 250 II (9 Channel).pff
(105.88 KiB) Downloaded 33 times
http://two-for-flinching.com
Return to “American DJ”
