Hi all,
after i updates FS to 3,5 i would tried to use easy view.
i see the icon in FS but nothing happend.
cant find it somewhere on the website.
maybe somebody knows the solution?
easy view and FS3.5
- FreeStyler Version: 3.5
- I Use FreeStyler for: Band
- Twitter: http://twitter.com/Never_mindMusic/
- Spirit
- FreeStyler Version: 3.5.9
Re: easy view and FS3.5
hi
did you allready patch a Fixture..
because if you dont have any fixture patched the buttons Doenst work..
/Spirit
/Spirit
yes it is the same file as before with the fixtures in it.
- Spirit
strange and i dont know how this happins it works fine with me...
Maby reinstall on a Differnt direcory name and also reinstall EV3d with it...
what is the best way to install it?
maybe i did something wrong?
- Spirit
as i'm a Beta Tester i have many Differnt versions of Freestyler on my pc..
But i allways add the version number to it..
So the install ask Where to install it ..
i Say c:/freestyler 3.5.0
or C:/freestyler 3.4.8
then the install ask if i also like to install Ev3d View and i enable this...
ok i tried to install freestyler again and enable the easy view button.
it gives me an error after downloading it
- Spirit
uhhmmmm oke strange then i dont have a Clue...
also if i try to download the beta software from Magic 3D Easy View it won't download.....
- Spirit
oke then it can be a Server issue with Nicolaudia..
so try tomorrow or next week and you can download it again
