I'm creating a Halloween display where I want to play a music track and a corresponding light show at the exact same time, so that I can have lighting changes happen at specific points in the music.
Is there a way to have Freestyler trigger a .WAV file, where I could then feed my laptop's speaker output into an amplifier?
Or any other ideas for how to accomplish this?
Music and Lighting Sequence Starting at Same Time Topic is solved
sirwesley
Re: Music and Lighting Sequence Starting at Same Time
If you are doing a yard display synced to music, there is a whole community dedicated to doing this, and I personally have had success with Vixen 2.5.
I hear there is a Vixen 3.0, but have not tried it yet. There was just an update in Sept 2012. Looks promising. Supports most any DMX controller as well.
http://doityourselfchristmas.com/forums/
This is also a good resource:
http://diylightanimation.com/
Hope that helps!
Hope that helps!
Balk2K
I've had success using a Digital Audio Workstation style program to fire MIDI messages to FreeStyler as it plays a song. You can map MIDI notes to different cue and override buttons and have them fire at just the right time. I've been using a program called Reaper to play music and send MIDI and you'll also need a MIDI loopback program to send it to FreeStyler. I was using CopperLan.
