hello all who read. i am currently new to the programme and the whole dmx process. i am currently trying to hook up my casa - ctl-dcm laser to the programme with very little luck. i have found a .ssl file that someone has made already to use with other programmes but am unsure of how to get it working with freestyler and have also tried creating a custom fixture programme but this has gone with no success.
any help or advice would be hugely appreciated!
regards
retroloving!
fixture file for my laser. help would be awesome!
- Admin
- FreeStyler Version: NULL
Re: fixture file for my laser. help would be awesome!
Do you have the dmx values for each channel?
Matt Hankosky
flickr.com/photos/mattxhank
(this is what i found before)
Here with the Control Parameter Chart Please:
Channel - function - Value = Description
Ch1 -Mode Value 0~49 = Close, Laser OFF
50~99 = Sound active mode
100~149 = Auto mode
150~199 = static patterns of DMX mode
200~255 = Dynamic patterns of DMX mode
CH2 - Pattern Selection 0-255 = 52static/dynamic pattern
CH3 - Position-X - 0~255 = Adjust position X
CH4 - Position Y - 0~255 = Adjust position Y
CH5 - Scanning Speed - 0~255 = 0 is speedy, 255 is slow
CH6 - Dynamic Patterns play speed - 0~255 = 0 is speedy, 255 is slow, has ten grade speed
CH7 - Static Pattern size - 0~255 = 0 is small, 255 is big
I hope this helps.
the link below will take you to the table on ebay
http://www.ebay.com/itm/RGPY-4...&hash=item43a816243e
100~149 = Auto mode
I hope this helps.
- FreeStyler Version: Beta
I just had a fast look on the dmx table.
It is not that complex.
Export the fixture you have tried to create and upload it here.
Then I will guide you.
