midi pages problem
pelopinxu
midi pages problem
Post by pelopinxu »
Hi to all!
I have a problem that is driving me crazy. I created my config file a year ago and it worked since one day that stops. I don't know if it's a config problem or what...
I have one layer where I control the sequences, with one button I change the page and I control directly the parameters.
The problem is that when I press that button, the faders doesn't set their correct position, it seems that BCF2000 isn't receiving data, but If I try to move it on the software the control surface starts moving, but is not receiving the position of the faders.
I don't know If I'm clear on the problem, If anyone could help me will be amazing!!
Thank you!
aslonnes
Re: midi pages problem
Post by aslonnes »
hello
I have exactly the same problem. It is perhaps a problem of version freestyler?
hi
Yes there is a Issue with the Midi Feedback its solved on the Latest Beta.
So you need to wait untill the latest Public version wil be released..
aslonnes
Post by aslonnes »
Hello
thank you. In version 3.5.0?
no this beta isnt released yet so lets call it 3.5.0.1 ;)
pelopinxu
Post by pelopinxu »
Thank you so much spirit!!
I would had to ask before, I was going mad reloading the file into the controller and thinking it was broken or something like that :)
Really looking forward for this update! Cheers!!
pelopinxu
Post by pelopinxu »
just a quick question, what was the lastest version that midi feedback works properly? Where I can download it?? Only while I'm waiting for this amazing update... :)
Yes 3.4.9 but you cant download it any more 3.5.0 is the latest one.
sorry
pelopinxu
Post by pelopinxu »
I'm still having the same problen on version 3.5.2... :(
hi can you upload you .SYX and .FMS file so i can take a look at it?
dzsie
Post by dzsie »
Hi Spirit,
We have the same problem as pelopinxu. (also used in the latest version - 3.5)
Return to “BCF2000”
