I am new here so maybe its something I am doing wrong?
I am building a TS display for a 7 inch touchscreen display ( Mimo Display Link). As I was arranging the buttons, and pages, it became apparent that the button text was not persisted after an FS restart. This was on version 3.4.8. I then built it offline on a dev PC and the same problem occurred. The text seems to written to the .fts file OK (the default numbers replaced by the text you have entered), but only the default "numbers" are shown on the default TS 2 interface layout. This means you cannot label the buttons...
If you attempt to load the .fts file via "options/load" the custom text flashes on the buttons momentarily, then reverts back the the defaults.
Is this a problem anyone else has experienced? I am a bit stuck right now as I need to TS display to drive my new DJ / Light system...
Any help appreciated...
Jim
RnJ Music
This is on Win 7 64 bit, and currently version 3.5 of Freestyler... ( although its the same behaviour on 3.4.8)
Button Test on Touch Screen user interface 2 Topic is solved
Jimx
Re: Button Test on Touch Screen user interface 2
I have lodged a bug report (906) on this....
Excuse my spelling it should be " Button text on Touch Screen user interface 2
- Spirit
- FreeStyler Version: 3.5.9
hi you did also now you can the button text how you like it to have on the Option -> Captions.
/spirit?
/spirit?
- Spirit
i tested it but if you set the Captions as"use custom Captions" and you restart fs the cunstom capions stays the way how it should be..
i allways have all the Captions Options OFF this wasy TUI2 will use the Names you put on the Sequences, Overridebuttons or Cuelist buttons on FS
