I've created the following for the Mega Par profile. The only thing I can't seem to get working is the 3d rendition. The strobing channels don't seem to behave to STROBE OFF settings.
My understanding is that the channel setting for no strobe is values 1-15 and 16 through 256 should be the variable strobe. When the settings are 1-15, the lights do not 'appear' in the 3d window as on but once you get to the strobe settings they seem to work. I welcome any advice, updates or comments. By all instructions, it 'should' work.
I've programmed this fixture based on the full functionality of 7 channel mode.
ADJ Mega Par Profile
gothambeat
Mega Par Profile.ssl2- 3d SSL version - Mega Par Profile
- (46.45 KiB) Downloaded 87 times
ADJ Mega Par Profile.pff- ADJ Mega Par Profile
- (99.86 KiB) Downloaded 126 times
- Spirit
- FreeStyler Version: 3.5.9
Re: ADJ Mega Par Profile
sirwesley
This is the exact same fixture functionality as Gothambeat's, but I updated the graphic with a transparent background. More aesthetically pleasing for me than the white background. Thanks Gothambeat for putting this together.
alargepenguin
I am complete NEWB trying to learn how to get the Mega Par Profile working with freestyler. When i try to load this in fixture creator 6.3 it hangs on the importing. could you please explain how to create this fixture or how to import this profile in step by step?
- djSupport
Hi penguin we had an issue with files try it now and it should work!
