I'm probably missing a setting, but I just can't figure out why the Cue/sequence keeps through the sequence while I have it set for sound.. I saw a note indicating that when I create the sequence I should be in transparent mode with the fade disabled, but I tried that and it didn't make any difference.
I slowed the chaserspeed and the master all the way down, but neither goes to zero. So this puts each scene at 65 seconds. That's not terrible, but when the music stops I want the lights to stay on scene. Any help is greatly appreciated.
C
cue overriding sound 2 light
- Just started using FS
- FreeStyler Version: 3.5
Re: cue overriding sound 2 light
Hey guys I really could use help with this. I know I'm just missing something, but I would really appreciate a solution if anybody knows one.
Thanks for the help,
Clint
Clint
