I need a profile for this RGBW LED light. Its a common cheap led light from china sold like crazy
I can't get it right my self. I have never good luck creating profiles.
I figure someone has to have made a better one than what I have been able to put together as a generic profile.
Thanks in advance.
http://www.ebay.com/itm/LIGHTS-RGBW-186 ... 3cc40b705e
This above link has the channel value on it
DJ Light Supply 186 Par 64 Led Profile
nickhaas
- FreeStyler Version: 2.96j
- I Use FreeStyler for: Choir
- FreeStyler Version: Beta
Re: DJ Light Supply 186 Par 64 Led Profile
Hej nickhaas.
This tutorial should be able to guide you.
The ARC2+D should be the one.
You have to set the total channel no to 8
http://www.freestylersupport.com/wiki/f ... led_parcan
And then you just have to define the rest as macros.
Give it a try and we will guide you for the rest
