I have 4 Stairville SC-x50 Scanner. When the difference of Pan or Tilt is bigger, the scanners jump almost directly to the value. But if i select smaller differences then scanners fade very slow to the value.
I am in Snap mode. How can i create direct snaps even if I am little movements?
Scanner fades in little moves. big moves snap!
- FreeStyler Version: 3.4.8
- FreeStyler Version: 2
Re: Scanner fades in little moves. big moves snap!
Same problem here... But it's not the software. It's the firmware in your fixture. For example, I have the Intimidator 300 LED. The main mother board needed to be replaced on all four so that slow movement can be turned on and off. There should be a slow movement and fast movement option in your fixture channels. If not, ask tech support of the fixture's manufactureer
