Variable Position on Stage - Scanner shall point at drummer
sva1889
Post by sva1889 »
Hi, I have a Question:
Is it possible to create variable positions f.e. for the drummer? the position (relative to the scanner) changes from one gig to another. In my lightshows i want to programm scanners to show at the drummer while he plays a solo in fix sequences.
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Re: Variable Position on Stage - Scanner shall point at dru
Post by Uriahdemon »
I would set up a cue to do this and put it on a cue button.
Open the 'Create Sequence' and select the moving heads. Then go ahead in each step and position them with colours and effects etc. Save the cue and then open it within Cue window. I would then save it to a cue list button to be able to just press the one button and off your moving heads go.
Be aware that some folks say to address some fixtures with the same DMX address so they will just follow each other. If your moving heads are either side of the stage you will need to set the DMX address's seperately to allow you to focus them in on a centre point, i.e. the drums.
Rgds
Mac
