Hey Everyone!
the fixture creator is abit complex for me and I need this to be done right
I have 3x24 channel Chilli Dimmer racks DMX address starting on 1-24 25-48..etc you get the point
can someone please make a fixture for this? or do I not need a fixture file for it? and send the DMX signals on the respective channels?
Request Zero88 Chilli dimmer 24
- FreeStyler Version: 512
- Admin
- FreeStyler Version: NULL
Re: Request Zero88 Chilli dimmer 24
Just add 72 single channel generic par or pin spot fixtures. Start at channel one and end at channel 72.
In freestyler go to setup
Add/remove fixtures
Select parcan
Select par_white (or any color don't matter)
Click the right arrow
In the number of fixtures to add, set it to 72.
Click add
Click close
You now have 72 lights to control.
Add/remove fixtures
Select parcan
Click add
Click close
Matt Hankosky
flickr.com/photos/mattxhank
so im just patching right through? sending a direct signal so there's no need to patch the dimmer.
Okay thanks alot its easier this way cause im running alot of Mac 550's and 2000's aswell.
Thank you!
Thank you!
