Theatre Uses Topic is solved
ronty322
Theatre Uses
Post by ronty322 »
Hello everyone! and well done to the developers for this software.
However there's only one thing that eludes me, How do I set SCENE's (NOT CHASERS) and program them to the cue list? and how do I use the cue list like I would when I program onto a Bull frog or a strand desk and then using a GO button such as the ones on every good lighting desk to play the scenes as well as control the fade up/down and LTP?
I have already gone through the sequencing tutorial which is Extremely Vague and didn't really do what I wanted to do.
please try to answer this as fully as possible as I only have until march to get this running on 46 Mac 550's :fs:
Re: Theatre Uses
hi freestyler isnt made for Theatre uses....
Freestyler is made for Poeple that never used DMX software before.
Also for the profs you have the Submasters as all the Prof. lightdesk have.
But i would recemmend to look at the GO Monkey Cue stack. Its a Add-on for freestyler..
viewtopic.php?f=38&t=2787&p=11067#p11067
ronty322
Re: Theatre Uses
Post by ronty322 »
I know this but it means being able to program shows at home and uploading onto my ION console through artnet, which so far has worked well. I needed the go feature to make this aliitle more simple, this plugin looks great!! thank you for replying!
Also im abit new to the program structure of FreeStyle so can i ask how do i install/patch/copy this plugin into Freestyle?
:fs:
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Theatre Uses
Post by matt »
Why not use the ion offline editor??
Matt Hankosky
flickr.com/photos/mattxhank
ronty322
Re: Theatre Uses
Post by ronty322 »
Our ION's Artnet really doesnt seem to like going from offline to online, something that we need to have repaired but for now this is a good solution
