I noticed that one thing one cannot do is delete folders that chaces are stored in.
For example, if I create a folder to store a chase in but then decide not to use it, I can't select the folder and click delete.
Can this be implemented on the next release?
2.96i - Feedback - Slight Flaw Topic is solved
- FreeStyler Version: 4.01
Re: 2.96i - Feedback - Slight Flaw
just do it in windows, outside the software
Tom
Indeed I could, but it would be far more convenaint to have the feature imbedded in the program.
