Phantom 50 Led Spot
cyberb0b
Commited FS Forum helper
Phantom 50 Led Spot
Post by cyberb0b »
Showtec Phantom Led Spot
This is made for the 13 channel setup.
Phantom 50 Led Spot.pff
cyberb0b
Re: Phantom 50 Led Spot
Post by cyberb0b »
V 1.0
Features, all colors, rainbow speed and much more.
cyberb0b
Post by cyberb0b »
Here is the screenshot so you know what your getting in to:
cyberb0b
Post by cyberb0b »
If you just want an template to create your own buttons as the rainbow like i did
You can download it over here:
If you export the images as web, it will slice the image for you.
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Just a quick question in regards to the rainbow. Will it only work for that fixture or will it work for everyone that has colours?
Regards,
Nathanrs93
cyberb0b
Post by cyberb0b »
The rainbow works only on this type of fixtures.
This has to do with the channel assignment.
Nathanrs93
What do you mean by "this type of fixture"? Do you mean Showtec? Do you intelligent lighting? Also, how did you get the beta version? I've been looking for a download link but can't seem to find one?
Regards,
Nathanrs93
cyberb0b
Post by cyberb0b »
Well... this is not an RGB type of fixture.. It is an White led.
And in this case, the colors and the rainbow are on the same channel (on the same color wheel)
So i used the macro to add some more options.
The question regarding the Beta, i guess you can better ask the forum manager.
cyberb0b
Post by cyberb0b »
V 1.1
small graphical fix
hi
the latest Public Beta version = 3.4.8 and can be found on the Forum main page.
the latest beta beta beta version can not be found you need to be a Beta tester.
But there are some little bugs that need to be fix but it will not take long before the new Public beta will be released.
last week the devolper ask us (Beta testers) if it can be released.
cyberb0b
Post by cyberb0b »
V 1.3
Made an fix for the color cycle
cyberb0b
Post by cyberb0b »
I dont know how to edit or delete my own posts, but here is version 1.4, as i saw that i uploaded the wrong file.
V1.4
cyberb0b
Post by cyberb0b »
Version 1.5 ,
Moved rainbow to color wheel.
Replaced graphics of Head, better quality
(see first post for download)
sunshine2013
Post by sunshine2013 »
Hello,
I have a two showtec phantom 75 led spot, and iam using a fixture to phantom 50 led spot.
Everything working good, but i have a problem with auto focus (phantom 75 led have it).
When iam changing the position in tilt movement in the second moving head the focus is changing?
Maybe someone know how to resolve the problem, or maybe someone have a fixture dedicated to 75.
With regards Sunshine
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi, does anyone have the 8CH fixture file please....???
Return to “Showtec”
