I wonder if anyone can help a newbie get his head around using the timecode feature on the cue sheet? I'm trying to create a light show for a band and so far I have created a sequence starting at 00:00:01 which consists of a series of colour washes using 6 LED PAR fixtures which then change colour every 15 seconds. At 00:01:15, another sequence starts which lights a couple of scanners to highlight members of the band. The trouble is, as soon as this sequence starts, the colour wash sequence stops. In other words, can I set up the cue sheet so that the timecode can trigger more than one sequence at a time? I know it's possible using the 'manual' buttons but can't figure out how to do it using the timecode feature.
Help with timecode feature please Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Help with timecode feature please
No this is currently unavailable.
The time code is designed to cycle through the sequences at the set times.
Matt
Matt
bamforp
OK thanks. Is this likely to be feature at some stage?
