Usually do pretty well with my fixture profiles,but I've been a failure with this one.
Attached is the manual and how I attempted to build my file.
Thanx for any help!
Chauvet pinspot LED 360 Topic is solved
Bigjd
pinspot 360 LED.pff- This is my attempt
- (73.36 KiB) Downloaded 54 times
LED_Pinspot_360_UM_Rev2_WO.pdf- Here is the manual
- (751.96 KiB) Downloaded 68 times
- FreeStyler Version: Beta
Re: Chauvet pinspot LED 360
Hej Bigjd
I am not sue what don't work as expected.
I have an idea of what you are trying to do and it should work.
However I would have done it a bit different like bellow.
Place Channel 4 on Strobe, Max =255, Min = 9, and off = 0.
All the gogos you have, place them in macro and use the Show-in function.
You can eventually place Pan Speed on Gobo 1.
