American DJ Revo Scan Led
- FreeStyler Version: 3.4.6
Re: American DJ Revo Scan Led
hello guys. i tried myself but it's not working. so please give a look at the pff file in the attach if it's ok.
here is the url for the manual http://www.americandj.com/pdffiles/revo-scan-led.pdf.
thank you.
thank you.
- FreeStyler Version: Beta
Hej Archaiks
Nice try.
I have made some small modifications.
Have a look.
The Strobe is not a shutter function so it need an off value.
As the light blackout function is placed on ch 3 I have used it as shutter and as gobo channel.
I have added the last values in the gobo tabel and given them a number icon.
I have changed the values to midt values so they are in the middel of there definitions range.
If it is possibel then create some icons the fits the pattern.
You can find more info on the wiki if you have not already been there.
Nice try.
Have a look.
thank you Jan for the file and for the explanations. will try in the afternoon.thanks again
I mentioned make some Icons.
A small hint could be place the beam on a wall and take some pic's.
Cut / Scale them so they fit the icon size 30x30.
Jan glad to let u know that it worked
thank again
P.S. Little disapointement about the device,bad move in slow motion.
- FreeStyler Version: 3.5.2
- I Use FreeStyler for: TV Broadcast
Hi Fs Members , i have a question if i download the revo .pff fixtures and try to install it , the error message past end of file shows me the programm , how i can fix / use this files . please help me im a new user
many thanks
artur
many thanks
artur
- FreeStyler Version: 3.3.4
