Help! Do I have to re-program cues? Topic is solved
johnnotestine
Post by johnnotestine »
I have been running freestyler with submasters. I have the following lights:
Blizzard Pars, Revo IV, Megapixel, & Martin Scanners
Things were not working right at the last wedding I was at and I think I may have changed addresses of my fixtures or something. Now my not all my cues are working correctly.
Do I have to re-program my cues or is there a way to tell what my fixture addresses were before? Before anyone asks, yes I was dumb and think I may have changed them on freestyler setup and on my lights. However, I am hoping there is a way to look at the cue and get back to what I had.
Any help would be great!
Thanks.
johnnotestine
Re: Help! Do I have to re-program cues?
While trying to fix my own problem I am noticing something strange:
When I go to "Show Output" and run my cues I can watch the DMX values change. All the cues work as they should except the lamp on/off cues. They don't change the values.
hmmm......
johnnotestine
The problem seems to be definitely isolated to my Lamp On/Off cues. They are quite simple and just a saved cue with the lamp at full power (snap or fade) and one with it off. They worked before.
All my other cues output when using, lamp on/off on all fixtures runs, but will not output. I have tried creating a new location with random lights and I still get the same issue, will not output lamp on/off. I can override the lamps and make them turn on/off-but that is a pain in the butt!
