Need pff file for Blizzard flurry wash
warrior8904
Post by warrior8904 »
I have been at this for a couple of days trying to get this up and running i have a Blizzard Flurry Wash i will post the manual with the info if somebody has it on file please message me thanks.
http://www.blizzardlighting.com/index.p ... sh-lumiere
i also have another moving head almost identical to this but the brand is different as well it is Envision Lighting TH 104-
Up for auction is a Mini Moving Head Light. This light was used for Display purposes only. We buy and rent these lights and we used this light to show potential customers how we will utilize them at their event. This light has less than 20 hours of use and was maintained in a clean smoke free environment. These are definitely some of the most durable mini moving head lights that we have ever purchased. We own several of these and as I mentioned rent them out to DJ's, Bands and for Private Events and Weddings. We have roaded these lights with no problems. These light are made to sit on a flat surface or they can be hung from a truss or light stand. They come with a bracket that you can use to hang them up side down. Included are all manuals so that you can get started as soon as you receive your new lights. Upon receipt of payment we will immediately ship both of the units. Please check out the specifications to see how really great these mini moving heads really are. Each light only weights about 11lbs and really are very compact for their size and put a bright punch in your shows. This auction is for Only One of the lights you see in the pictures.
TH-104 Mini Moving Head
http://www.ebay.com/itm/330766898555?ss ... 1439.l2648
Feature
• With DMX-512 LED signal
• 0~100% linear dimming; Special function
• Built-in procedures for a variety of lighting effects
• Run simultaneously from sound control without controllers;
• Optical system: Combination of high-precision quartz lens
• Optical loss is reduced to a minimum; Protection: all intelligent
• Temperature thermal protection and high-interference with electronic circuits
• 100000 hours LED life, Energy-Saving and environment-protective
• Pan: 540°,8/16bit, adjustable, electronic correction;
• Tilt: 270°, 8/16bit, adjustable, electronic correction;
• XLR male socket data output, locking 3-pin
• XLR female socket data pin configuration: pin 1 shield pin2(-),pin3(+)
Technical Parameter
• Input Voltage: AC90-120V, 50/60Hz
• Power consumption: 70W
• LED source: Ultra-bright LED 3w*18pcs, Quad Color
• Control signal: DMX 512
• 12CH Control model
• Pan: 540deg 16 Bit
• Tilt: 270deg 16Bit
• Carton size: 10.2”×10.2”×11.4”(1pc)
21.3”x9.4”x12.2”(2pcs)
• G.W: 22.1lbs
Re: Need pff file for Blizzard flurry wash
Post by Jan_K »
Hej
The Blizzard folks have some fixture for FreeStyler on there home page.
Blizzard_Lighting_Flurry_Wash.pff
(58.69 KiB) Downloaded 22 times
warrior8904
thanks i was able to get the blizzard going but the envision moving head picks up the movements but not the colors.
