How to reset Easy View Fixtures
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
HI, I am playing with setting up some cues and sequences in FS and playing them on EV. When I finish trying them out I do not know how to reset the fixtures in EV, it holds the last sequence I played. Any suggestions please...??
Mac
www.mclite.co.uk
www.mclite.co.uk
- Spirit
- FreeStyler Version: 3.5.9
Re: How to reset Easy View Fixtures
hi
EV just listen to the values FS sends to it.
so to reset all the Fixture value's you need to drag all the Sliders back to DMX value 0
You can also Use "Restore value" on the cue window so if you stop a Sequence from the Cue it wil go Back to DMX value "0"
- Uriahdemon
