In need of a Fixture file!
TimG
Post by TimG »
Hey all, I'm needing a equinox scantastic 4 .pff, i have got a ssl2 of the fixture but I can't seem to use it. If anyone has this file or has a little bit of time to make one Please cold you. Thanks
Tim
Equinox-Scantastic-4.pdf
(1.01 MiB) Downloaded 19 times
Scantastic 4.ssl2
(16.58 KiB) Downloaded 15 times
Re: In need of a Fixture file!
Post by Jan_K »
Hej TimG
The ssl2 fixture are for 3D easy view and not FreeStyler.
You need to create a FreeStyler fixture.
I just had a fast look at the data sheet and there are some pattern and macro channels.
They are not described with DMX values and this means that the one who are to create this fixture need to have the fixture to retrive the values for this.
This means that you most likely are to create the fixture your self.
