Freestyler on Windows 8 Topic is solved
shane_saintsfc
Post by shane_saintsfc »
Yes it works on a windows 8 touch screen table. :)
Re: Freestyler on Windows 8
yes i also have freestyler running on win8.
on mine laptop with touchscreen. :D
Only is seems like EV did not work on Win8.
djnyce
Post by djnyce »
did you have any errors with the usb drivers (2 das usb drivers)? i just did a fresh install with parallels and those drivers fail to install. is this a parallels problem or a windows 8 problem?
also does anybody now what the repercussions are of these drivers not installing?
