I have a que that only has a few steps. When it executes in a loop, it runs as expected. But, when I click the STOP que, it leaves the last executed fixture running. Meaning, if a strobe was firing, it doesn't turn off. Is this the expected result when stopping a que or should it turn off the last fixture?
This is only in the 3D viewer. I don't have these lights in operation.
Thanks.
Buck
Que process question
BuckinJB
- FreeStyler Version: 3.4.8
- I Use FreeStyler for: Film
- Spirit
- FreeStyler Version: 3.5.9
Re: Que process question
you can enable "Restore value" looks like a Blue arrow and you can find it on the CUE.
this will restore all the value's if you stop a Sequence.
Th0r4z1n3
- Twitter: http://twitter.com/Th0r4z1n3
Now that I know how to do it, I feel like such a dunce for not figuring this out on my own, but very helpful post.
