I need help with bezier shape!
brgroove
Post by brgroove »
Hello, I am a new user freestyler, working in a nightclub in Argentina and my question is:
  As I can offset the movements for the fixtures do not move together? :?:
  Working with 10 fixtures (2 PLS 575, 4 AmericanPro NEO 500, 4 575 AmericanPro II), and when I use the rectangle , I can not offset the movement,
the solution is to put each fixture to different speed? or is there another way neater? :?
Re: I need help with bezier shape!
hi you can roate the Shape.
so if you have 10 Moving light you divide 360 with 10
so fixture 1 set to o degrees.
fixture 2 on 36 degrees
fixture 3 on 72 degrees.
fixture 4 on 108 degrees
and on.... this way you can create a nice looking offset.
brgroove
Post by brgroove »
thanks spirit , but haven´t 360º of pan , the site is rectangular and in the middle is a division of columns, then I have one in each corner of the place = 8 and 2 + on the cabin
