Kam - LED Powerbar
biggus
Kam - LED Powerbar
Post by biggus »
Please see attached my fixture for the Kam LED Powerbar tested with a Enttec Pro DMX.
The fixture is 15 channels, however I've split the fixture into 2.
Kam Powerbar LED Master should be setup to control the first three channels
Channel 1 – Internal Programs, Auto Mode and Sound Controlled Mode
Channel 2 – Master Dimmer
Channel 3 – Master Strobe
Kam Powerbar LED Can This fixture has 4 cans and there are 3 channels each so you will need to add this fixture in 4 times once for each can, The reason I decided to septate the fixture up is so its easier to vision what is happening with each LED can.
Can 1
Channel 4 - Red
Channel 5 - Green
Channel 6 - Blue
Can 2
Channel 7 - Red
Channel 8 - Green
Channel 9 - Blue
Can 3
Channel 10 - Red
Channel 11 - Green
Channel 12 - Blue
Can 4
Channel 13 - Red
Channel 14 - Green
Channel 15 - Blue
Kam Powerbar LED Can.png (8.07 KiB) Viewed 19993 times
Kam LED Powerbar Master.pff
(15.11 KiB) Downloaded 137 times
biggus
Re: Kam - LED Powerbar
Post by biggus »
Fixture file attached
Kam LED Powerbar Can.pff
(2.92 KiB) Downloaded 133 times
Return to “Generic”
