Tap Sync slowing down?
spankthafunk
It seems when I use the Tap Sync it starts off good, but then starts to slow down. Anyone know why?
spankthafunk
bckeeping
Re: Tap Sync slowing down?
Hey Spankthefunk (nice name)
Are you sure that it is slowing down and not that you are *slightly* out of time with your tapping.
Even the smallest difference between your tap and the actual beat would get larger and larger over time, so it would seem that your tapped beat is deviating from the actual one.
Think of two pendulums swinging slightly out of time.
Does that make sense?
Ben
Ben
spankthafunk
Yea that makes sense but I'm using a click track and it starts out perfectly. But within ten seconds or so the bpm drops tremendously. Not a gradual slow down but a steep drop off.
