Hiya,
since some days im busy with submasters and already getting better with it.
im playing with scanners i was only searching for the speed only when i make the speed to the max in sequence it doesnt work with the fader... if someone knows a idea how to fix it i would like it;)
Greets,
Spikie
Submaster question
- FreeStyler Version: 3.4.8
- Spirit
- FreeStyler Version: 3.5.9
Re: Submaster question
yes your right this doesnt work ok.
on the lastest beta this is fixed.
but you can also set the speed with the speedslider on the CUEwindow.
and keep the scene and fade time on 1000.
hiya,
now the newer version is out, still this is not working.
i want to fix the speed of the shape with a submaster fader but when i make a sequence to the max for speed and then save it, it still goes to the max when i move the fader. or am i missing something?
Greets,
Spikie
Greets,
Spikie
- Spirit
ahhh Yes
you just need to Save the shape with the Speed (on the P/T window on 1000) and on the Create sequence window also on FADE time : 1000 Scene time : 1000.
Now play this back with the submaster..
If you look at the CUEWINDOW you also have Sliders these are the Speed sliders.
the Slider next to a Submaster is Used to set the Brightness or Intnensitie from the playing Sequence.
So that only used for Dimmer Sequences or RGB sequences..
It sure would have been great to be able to select if the submaster fader should affect Intensity of a dimmerchannel or the speed of other sequences:) I´d would have liked to be able to for example use an SM fader to both start and stop say sequences for Pan/Tilt on my moving heads, and at the same time control the speed of the same sequence. Could make some nice fade to stop moves and stuff live then
Perhaps possible to do that somehow..
