Leave Speed As Is Not Working
spankthafunk
Post by spankthafunk »
I have a show Saturday and trying to program but running into problems. I have a MIDI Controller with a knob controlling the cue speed. I have it set in the submaster to "Leave Speed As Is" but when I move the speed and hit play, it resets back to 100%. Any help is much appreciated!
Re: Leave Speed As Is Not Working
hi again.
i'm the one how asked for the feature to the devolper.
and i never had any problems alsio tried it again just for you and it works perfect.
but you can enable this feature on each submaster so be sure you enabled it on each submaster you like to have this feature on.
spankthafunk
It's enabled on every fader. Maybe I found a possible bug.
I have Run setup on a midi button on my controller. If I use that button the speed as is doesn't work. I have to actually hit Run with the mouse on the submaster for it to work properly.
Can you verify this on your end? Using Korg NanoKontrol2
hi i tried it again with the BCf2000 but that no differnt because you use Midi CC# note's and thats all the same.
but evrything works perfect i have no issue's RUN button work ok , and leave speed as if also work perfect...
no bugs for me..
and maby nice to know i'm a Beta tester as i know all the bugs on freestyler.
and 3.4.8 works real nice only do not play more then 16 sequences at the same time then you will find one bug.
and im realy hard to the devolper if it goes about playingback your sequences because that allways need to work Perfect! otherwise poeple will look at me if anything will go wrong durring playback.
spankthafunk
Yea for some reason I hve to manually hit run for it to work correctly. After I Hit it the first time I can use the midi controller no problems.
I'm running stable version of 3,4,8
