Before anyone gets excited about "this is the wrong place to thread this," bear in mind that, for some reason, the bug reporting page has problems. I'm assuming that it's in work.
Anyway, 3.4.8 has a weird bug in it with DMX 400. I'm using homebrew RGB LED cans, with RGB channels set R=1, G=2, B=3. In chaser mode, the lights simply oscillate between two different colors. There's no fading between all available RGB colors (like what could be done in 3.4.6), and the speed control is set rather high for default. I've tried everything that I can think of to "trick" this into working- "Use in DMX 400," "Do not use in DMX 400," set it for chaser, set it for static, set it for all same color, set it for 10 vivid colors, checked, re-checked and checked again the channel addresses... all with no-go results. I'm about to roll this back to 3.4.6, because I just can't seem to get 3.4.8 working as I need...
FreeStyler 3.4.8 bugs
- Just started using FS
- FreeStyler Version: 3.4.4
- Spirit
- FreeStyler Version: 3.5.9
Re: FreeStyler 3.4.8 bugs
yes your right the FSBT does not seems to work anymore but i will mail de admin again.
because i allready did that a week ago.
Err, never mind... got it figured out. Had to have "Fade" and "Intensity" buttons selected first, then worked out the individual controls... Anyway, all is good! (Now to see if I can get a Tascam US-428 to function with it...)
And, I have the Tascam US-428 working with Freestyler!It works just like any MIDI device, just set your note to the control you want, and keep it on Start.
- buttza
- FreeStyler Version: 3.6.4
Nice Job.
