LED par?
things
LED par?
Post by things »
I recently bought a LED par, and tried it out with freestyler using a similar fixture, but it seems the channels are slightly different to mine. I was using the "Weildamark"(sp?) LED par fixture, as it looked similar, but the blue channel seems to be reversed. Its somehow currently set up, so that the blue increases when i decreas the value, and rises when i raise the value. How would i reverse this back?
kikabyte
Re: LED par?
Post by kikabyte »
Go into fixture creator. Locate the 'Weildamark' fixture file and load it up. Edit the Min & Max value's to work the right way round for the RGB channels and then save it, or save it as a different name so you know its the one you've edited. You may need to delete and then add the fixture into freestyler again to get it to work correctly.
Eg Min = Value 0
Max = Value 255
