Fixture in DMX400 and sequence or cue Topic is solved
studijo
Post by studijo »
I use 4 RGB led PAR64's which I use with the DMX400 chaser. Furthermore I'd like to use the same fixtures in a sequence.
I've tried several things but I'm not able to come to a solution.
The only way I found now is to use an override button. With this override button the first scene of the sequence is working but that's it. The complete sequence isn't working and that's what I want.
I hope there's another way to do this.
I also tried to 'blackout' the DMX400 and run the sequence but then the PAR's are complete blackout and the sequence isn't working.
Thanks anyway for your reaction !!!
