I am new to using Freestyler and I am trying to start it to use in my shows ...
But I have the following problem: I select a moving head, I open the shutter, and increase the intensity to the max, but I do not see the beam in the Easy Viewer.
However, if use the sealing effect (strobe), the beam appears in the Viewer Easy ... I can only see the shows where I use strobe in moving heads!
The rest of the features (pan, tilt, etc) seem to work properly.
I hope you can help!
Thank you, greetings.
I cant see the light beam! Topic is solved
skatejack
Re: I cant see the light beam!
I forgot something important!
I use:
Windows 7 64bit Professional
Freestyler 3.4.8
Magic 3D easy view 2012.5.21.3054
I use:
Freestyler 3.4.8
- FreeStyler Version: Beta
Easy view fixtures are not the same as FreeStyler fixtures.
The Easy view fixtures are also user created and they may have errors.
Think you have to open Scanlib (Fixture editor) in easy view and have a look on the fixture if it is created correct.
