Fixture needed Eurolite tmh-4 and Elation tri64b Topic is solved
fredericdeprez
Post by fredericdeprez »
Hi
I just have bought 4 eurolite tmh-4 movingheads en 16 Elation tri64b par. Now I was looking to create fixtures for these lights but i dont understand how it works... Is anyone who can help me to make them? Or maybe for the TMH-4?
Thank you for helping and sorry for my bad english!
Re: Fixture needed Eurolite tmh-4 and Elation tri64b
Post by Jan_K »
Hej frederifdeprez
Have a look here.
http://www.freestylersupport.com/wiki/fixture_creator
There are all the information you need.
There are a "Before making a fixture" and a moving head example.
Don't understand how it works is not valid.
Here is an image of the fixture that should be of the correct size.
Give it a try and when you run into problem then ask.
Looking forward to help you.
fredericdeprez
Hi Jan
Thank you for the information, i will try it tomorrow and let you know if i understand it. The link look in the first way a good option the learn it.
Kind regards
Frederic
fredericdeprez
Hi Jan
I've tried it with a the par eled tri64b, the most thing works but the the red color is not red but more green.. But I think that i will find that. I've tried also the tmh-4 movinghead but that wont works. I did everything like the manual but every step i try in freestyler is something different... Red color is tilt and pan is like flashing green,... I think that my english is to bad to understand everything of the manual...
Is it possible to help me for a good fixure of the tmh-4? I will look further for the eled par.
Thank you for helping!
Kind regards
Post by Jan_K »
Hej again.
What mode are you running the tri par in.
It is a quit simple fixture.
Try export the fixtures, (In Fixture Creator), as they are and upload them here then I will try guide you.
