I have a stage with 4 RGB LED par 64 , and 2 led mini moving head's and the program is constantly breaking.
This start happening with the new version of Freestyler, after i have a version that to start and stop a cue i use the same key, and now i need 2 diferent keys) i don't now the version, actual version is 3.4.8
Sorry my english
Thanks all
Pgrogram Breaking
- FreeStyler Version: Beta
Re: Pgrogram Breaking
Just to clear it.
You are using keyboard shortcuts.
And you are linking in to what function ?
If you previously only used one key and now need to use two then it could be that the key has changed from a toggle to a single function.
There has been some large changes in the external control. Not that you will see them on the userinterface but in the code bellow.
And.
Are the cue just stopping or does the program crash.
And.
joaopedrocmp
The previously version of the program dosen't crash ( i don't know the version, i notice that have a alteration on start/stop cue1 shotcut, to a start cue1, and a start cue 2).
Now, with the last version, in 4 houres the program crashed above 10 times.
i'm thinkinng, it could caused by i don't have a termination?
No.
There is nothing returned to the program on the cable connection.
You can change the interface to virtual and restart FreeStyler.
Then you run without the USB - DMX dongel and you should see the same result.
Also try to remove the shortcuts and use the the start / stop in the cue panel.
joaopedrocmp
Ok, i'll let the program run withou the dongel
I'll say something later
