Pan/tilt problem Topic is solved
madhatter
Pan/tilt problem
Post by madhatter »
Hi! I created a custom fixture for the Proel PLML575EPS moving head.
Everything is working fine, apart from pan and tilt.
When I use FreeStyler with the Magic 3D visualizer each movement I make in the pan/tilt panel (arrows or grid) correspond to the correct movement in the visualizer.
But when I connect my real moving heads to the Enttec DMX USB Pro the movements are not the same as FS and M 3D.
Note that the real moving heads are placed upside down attached to a truss, with me facing at the display and the connections on the rear.
How can I fix this problem?
Thank you for your help in advantage!
