Resolume
- buttza
- FreeStyler Version: 3.6.4
Resolume
Hi, I was just wondering if Freestyler would run Reolume through DMX. I know media servers use about 140 odd channels but I was trying to work out an interface through freestyler for it. Any ideas anyone?
- djSupport
Re: Resolume
Yes you use the Generic Profiles viewtopic.php?f=23&t=777 and use the sliders in FS http://www.freestylersupport.com/wiki/f ... ol:sliders
You'll know what sliders you use as you'll be setting up the dmx values in Resolume (This is the only help I can provide on this but hopefully you'll get it
- buttza
Re: Resolume
What if I created a fixture profile for each layer. Works out about 37 in each layer. And apply similar parameters for it that resemble the resolume controls that should work? Maybe??
- djSupport
Re: Resolume
FS allows you to do what you want, make a fixture using gobos so you have clickable buttons to perform some features! They won't be gobos but you'll create a little. Pic so you know what they are or use macros or just the sliders its what is easiest for you! Just remember if resolumes running on another pc or the same pc you need a seperate device for dmx in.
I.e 2x enttec pros one fordmx input in one for dmx output!
