How Do I Create an ADJ 38P LED Pro Fixture?
newj
Post by newj »
I went into fixture creator and started creating a fixture for the MAerican DJ LED Pro using the table in the spec sheet for this fixture. I can get it to work in freestyler. Also, I can't figure where to enter channels 4 and 6 for this fixture. Channel 4 is listed for NOTHING from 0 to 7 and COLOR MACRO from 8 to 255. Channel 6 has multiple functions at various addresses as follows;
0 - 31 NOTHING
32 - 63 DIM BRIGHT
64 - 95 BRIGHT DIM
96 - 127 DIM BRIGHT DIM
128 - 159 COLOR MIXING
160 - 191 3 COLOR CHANGE
192 - 223 7 COLOR CHANGE
224 - 255 SOUND ACTIVE
Where do you enter these functions in fixture creator Also, I bought a USB to DMX interface cable on eBay and I cna't get it to work. I may be having issues with the uDMX driver. Anyone know where I can get a good copy of the driver?
thks Jim ^_^
newj
Re: How Do I Create an ADJ 38P LED Pro Fixture?
Post by newj »
I meant to sayI can not get the fixture I created to work in freestyler.
Post by Jan_K »
Hej newj
Please export the fixture and upload it here and I will try to guide you.
You have been looking in the "Wiki". There are some tutorials that may help you.
http://www.freestylersupport.com/wiki/Fixture%20Creator
Uncle Eazy
Post by Uncle Eazy »
Here's mine. Pretty basic.
38 LED Pro.pff
(34.55 KiB) Downloaded 36 times
Post by Jan_K »
Hej Uncle Easy.
Looks ok but I will prefer to have the color control on the RGB channels.
In this way the color will also work if someone want to use global colors as control.
It is not necessary to have the colors as macros.
Just change the color palette in FS to basic then only a few basic color icons will appear.
I have made the easy part of the fixture here.
If you want then you can enter the tricky part in the macro.
It is the “color macro” channel 4 and the whole channel 6 control.
I don’t have the fixture so I can’t test or enter these function but I can guide you if you want.
38P_LED_PRO_3ch.pff
(3.44 KiB) Downloaded 34 times
38P_LED_PRO_6ch.pff
(3.48 KiB) Downloaded 43 times
38P_LED_PRO_7ch.pff
(3.5 KiB) Downloaded 45 times
Return to “American DJ”
