Where can you download the fixturecreator software? Topic is solved
newj
Post by newj »
I cannot believe that I cannot find anywhere on this web site where I can download the fixture creator software. Can anyone assist?
Jim
Re: Where can you download the fixturecreator software?
Post by Jan_K »
It is a part of the FreeStyler instalation.
Under windows "Start button" Go to your FreeStyler folder and there you will find Fixture Creator.
newj
Post by newj »
Duh! I feel like an idiot. I was just starting nfreestyler from the deesktop. I didn't even think to go to the program listings.
Thanks,
JW :shock: :shock:
Post by Jan_K »
I can imagine. :D :D :D
But to take it from the positive side I think I will make a page on the "wiki" that describe what the FreeStyler software in general are and what the different programs that are incluted are used for.
