Hello all
It is possible to automatically reset the time without press the reset button when using pc timecode enabled. it was interesting to get doing a reset automatically when the cue list gets the last sequence, so it can be started again the sequence from the beginning.
Or it was nice to get one sequence running for a period of time, independently of the number and time steps.
thanks
Timecode enabled reset Topic is solved
- FreeStyler Version: Beta
Re: Timecode enabled reset
Hej Alvarinhas.
It is not possible to make an automatically reset on the time code.
I am a bit interested in you application.
You have more sequences you start at different times.
None of them are looped.
When the last started sequence has elapsed then it has to reset the timer so you just has to press start again to restart the whole cue.
Alvarinhas
"When the last started sequence has elapsed then it has to reset the timer so you just has to press start again to restart the whole cue."
yes thats it... but as im a keyboard player solo, so i cant play, sing and press start do restart the cue from the beginning. if i could do this restart automatically it was very good, and let the light show run without deppending of my actions. i could select the cue at the begining of the music and let the FS control the light show without do any restart or action to reloop the cue in use.
thanks
thanks
