I have two Stairville 126 50 cm LED Bars, but I can not get the strobe function to work in the Submasters.
If I create a single step cue with strobe on, it works fine. Also in the cue-window.
But when I put the cue in to the submasters window, something goes wrong. Running the cue in Submaster, only turns the light on. It doesn't strobe.
Any ideas?
LED bars cant strobe Topic is solved
- FreeStyler Version: Beta
Re: LED bars cant strobe
Hej Peter.
You can try to remove all sequences except the strobe from the cue.
And open the output monitor.
In the output monitor you can see what happens / what value the strobe channel are set to when your strobe sequence are running.
You can then add the other sequences one by one and see when in goes wrong.
I guess that you have more sequences that control the strobe channe at the same time.
