The response is urgent because I have it working by Saturday (07/07)
FreeStyler does not work with the interface "Digital enlightenment".
The interface works with this PC.
I have tried both PC_DIMMER and DMXControl and works with both.
On website it says that FreeStyler will also work with this interface.
Do you know how to use it with FreeStyler?
My O.S. is Windows 7 Ultimate 64bit
FreeStyler - "Digital enlightenment" Interface Topic is solved
Flip
- FreeStyler Version: 3.3.6
Re: FreeStyler - "Digital enlightenment" Interface
Hey,
you need to copy some dll files from the project archive into the FreeStyler working directory (C:\Program Files\FreeStyler\). I have copied all dll files: usbdmxsi.dll, usbdmx.dll and lcm_dmx.dll. After that, it should work fine.
seattle_mike2000
- FreeStyler Version: 3.5.5
- Twitter: mishagrin
I would like to get more info 2, I used win 7 worked fine now I use win 8.1 it comes on for 1 sec yellow and then shuts off, I hope someone knows the answer 2 this
thx
mike./
thx
mike./
MAAC
- Just started using FS
It's in german, but it has something to do with power saving features of windows 8.1
1) regedit starten
2) Den Schlüssel HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\VID_04B4&PID_0F1F suchen und öffnen
3) Je nach schon mal angeschlossenen Interfaces sollte es mehrere Unterordner geben, alle enthalten einen Ordner "Device Parameters". Den nächsten Schritt in allen dieser Unterordner ausführen
4) Es sollten dort die folgenden 4 Werte zu finden sein:
AllowIdleIrpInD3 = 1
DeviceSelectiveSuspended = 1
EnhancedPowerManagementEnabled = 1
SelectiveSuspendEnabled = 1
Diese Werte mal auf 0 setzen und dann den Rechner neu starten.
1) regedit starten
