Elminator Electro 196 II
Download other Magic 3D Easy View Fixture files created by the community here.
Koshy
FreeStyler Version: 3.4.8
Post by Koshy »
I have 8 Elminator Electro 196 II. I have been using these fixtures for a while now,
I patch together channels 2,3,4 and 5,6 and 7,8 So there are only 1 Red 1Green and 1 Blue
Chan 1 Control
Chan 2 Red 1
Chan 3 Red 2
Chan 4 Red 3
Chan 5 Green 1
Chan 6 Green 2
Chan 7 Blue 1
Chan 8 Blue 2
How do i make or get a Magic 3d easy visualizer file for this fixture ?
http://www.eliminatorlighting.com/pdffi ... 196_ii.pdf
Thank you.
Re: Elminator Electro 196 II
Post by Jan_K »
3D magic are installed with a program "Scanlibrary Editor".
You have to use that program to create the fixture for "Magic 3D"
Koshy
Post by Koshy »
Do I download the entire Sunlite Suite package to get the Scanlibrary Editor app ?
Thanks !!
if you install freestyler it ask if you also like to install the 3dView / sunlite suite.
enable this ans everything you need will be installed.
and scanlibary can be found on the Freestyler direcorty.
but i'm not sure if you can create your fixture the same as in realy life.
Koshy
Post by Koshy »
oh, dang im dumb, sorry.
Return to “Magic 3D Easy View Fixture Files - User Created Downloads”
