I just bought a Varitec LED animation curtain. Can´t find or get a hold of any good support, so I try you geniuses here.
I would like to make some of my own programs. Nothing complicated, maybe just some words and full one colored screens, but how can I do this?
The pre programmed animations are on an SD card and are .bin files.
Thanks for your help and input.
How to program LED curtain w .bin files?
- Spirit
- FreeStyler Version: 3.5.9
Re: How to program LED curtain w .bin files?
hi i look at the movie on Youtube about the Curtain.
and the SD card should be in the DMX device you have from the Curtain.
so you can Activate the Animations from the SD crad with DMX.
and i could not found a Manual about the Curtain so i have No clue how to can controll this Curtain.
7clighting
Hi,actually you can make your own program by the sofeware via the computer.
The SD with some presetting programs, you only insert it into the dmx controller and it will be easy showing on the led video curtain.
