Following the turorial on wiki:
- selected "virtual interface" in Freestyler
- added a simple par in Freestyler
- opened Easy View from Freestyler menu (in Easy View it says: "controlled by Freestyler")
- added par in Easy View
- tested the connection by moving the slider: par in Easy view is working
- changing color in Easy view to another color: par in Easy view no longer working
Must be doing something wrong. But what?
thx for the help
CH
Color change not working
- FreeStyler Version: 3.4.6
Re: Color change not working
I'm having this exact same problem. Can anyone help?
Thanks!
Thanks!
- FreeStyler Version: Beta
What fixture in EV are you using.
- Spirit
- FreeStyler Version: 3.5.9
Yes this happins with parcans also many mh will not turn on the light only is you use the schutter you have light.
But you need the .exe file from the latest beta you can download from the nicolaudia webpage.
But if im home i will post the corret .exe file
- Spirit
hi i cant upload a File bigger then 2mb But i allready made a Explanation how to fix it on this link.
viewtopic.php?f=56&t=4526
