I need a fixture file for a Colorkey Par 64 LED 1 watt. I haven't had much experience with this brand, actually had not heard of it until after it was purchased. This is a 6 channel light with various macros. Any help appreciated even if you could get me a head start on setup the fixture file. I have attached the manual with the DMX mappings. I have also attached an image for use in the fixture file.
Thanks in advance for any help you can provide
Colorkey LED Par 64 1 watt Topic is solved
compguywill
- Par64 Image
- ColorkeyPar64.jpg (29.5 KiB) Viewed 368 times
ColorKey - 1Watt LED Par 64.pdf- Here is the Manual
- (160.3 KiB) Downloaded 118 times
