sequence buttons Topic is solved
bobflame
sequence buttons
Post by bobflame »
I am using freestyler in a live performance application and am finding that the sequence play buttons are to small to keep track of . i hit other buttons than the one i want sometimes. I see these bigger buttons on the left of the sequence play list but not sure what there are . i cant get any sequences to move to those buttons so im wondering am i missing something or is there a better way ?
Re: sequence buttons
hi
The buttons on the left side are Cuelist buttons, if you press that button it will play all the sequence that are in the cue at the same time.
you like to have bigger buttons then i recommend to look athe Touchscreen userinterface 2 here you can make you own Lighting desk and it haves bigger buttons.
you can also use touchscreen userinterface 2 with the mouse.
look at the frrestyler options to enable TSU2.
