Hello,
I am just trying free styler, with 3 devices, which are not plugged in. Will sound 2 light only work if the DMX devices are plugged in?
And is there anyway to add a microphone plugged into my laptop to the audio source?
Many Thanks
Cameron
Sound 2 Light Topic is solved
- djSupport
Re: Sound 2 Light
sound to light will always work even without dmx devices just you wont see any reactions unless you use the 3d visuliser, you could perhaps buy a usb soundcard that should add another input for your microphone.
