QTX_TRITON_SCANNER
ColinD
QTX_TRITON_SCANNER
Post by ColinD »
Try this.... unzip and copy the files to the correct places.... gobo's (QTX_SCAN_xx_xxx.bmp) and fixtures (QTX_TRITONxxx - the bmp and the .fxt)
The gobo's should be the same for QTX 'TITAN' - 'barrel' scanners too... so I've called them QTX_SCANxxxx basically...... Number and DMX Channel number in file name to keep things simple.
Also included a higher res picture of the fixture and the manual in the archive too.....
I've not done anything fancy with the gobo rotation or done any macros.... but the gobo images are spot on !!
Any problems give me a shout, and feel free to add to the the archives etc......
Hope this helps, Regards, Cols
QTX_TRITON_SCANNER.zip
(590.53 KiB) Downloaded 116 times
ColinD
Re: QTX_TRITON_SCANNER
Post by ColinD »
Ahh.... Try this pff file !!! - Should make things easier :)
QTX_Triton.pff
(97.83 KiB) Downloaded 118 times
Return to “QTX”
