DMX Universes Topic is solved
MuschelInBlau
DMX Universes
Hello guys,
i have a second Enttec open DMX Interface and i want to use 2 Interfaces in Freestyler.
How?
How?
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: DMX Universes
This is currently not supported, only one universe is currently supported with a maximum of 512ch.
There are no current plans to support more then one universe.
Matt
Matt
- Mattotone
Re: DMX Universes
Whilst a good idea, would require a total rewrite of the the way the software works.
I don't honestly think the work involved will benefit many users as 512ch of dmx is more then adequate for the majority of users currently using freestyler.
Matt
Matt
- djSupport
Re: DMX Universes
just buy two laptops! 1024!
sowndman
Re: DMX Universes
I think it comes done to if you can afford enough fixtures t need more than 512 channels, you have the cash to purchase a software packe that supports multiple universes.
- djSupport
Re: DMX Universes
Well said!sowndman wrote:I think it comes done to if you can afford enough fixtures t need more than 512 channels, you have the cash to purchase a software packe that supports multiple universes.
- remco_k
- FreeStyler Version: N/A
Re: DMX Universes
Time to dig out this old topic.
Recenlty I worked with 2 showtec pixeltrack pro's, put them in 20 channel mode for various reasons, one of them because freestyler can't support like 160 channels per fixture. (I know the workarounds for that, but thats not the issue now)
So that is not why I kick this topic.
Thinking of this, nowadays there are a lot fixtures that have/need many DMX channels. Like I said; a simple pixeltrack can go up to 160 channels other brands maybe more. Only 3 can be used in a single DMX universe. Then 32 channels are left over for the rest of the equipment. So one LJ can put in 1 nice movinghead and then he's out of channels for the 2nd moving head.
I did'nt have this limit in real life yet, but I can image it will come across one day, especially when, for example, there are 4 pixeltracks in 160 channel mode needed.
Buying 2 laptops won't be neccesary for me, I already have 2. One for by light jobs, complete with beer and other sticky stuff on it, and one for regular home use where my fingers don't get glued on when I touch it.
That will be a 'solution', I know that.
So,without damaging the good laptop, it will be nice to take in consideration to change the internal structure in FreeStyler so that it supports multiple interfaces. If prossible even 2 different brands and models and number of channels, each one controlling its own DMX universe of up to 512 channels.
I know FreeStylers internal structure is not prepared for this, and it would be a lot of work, but it could be a nice addition one day.
- djSupport
Re: DMX Universes
Onge the make a donation is actually for Raph its Raph's donation page from the website for Freestyler maybe I should make that clearer!!
THW Mark
Re: DMX Universes
a nice workaround could be to allow running of two instances simultaneously, both with their own config file. (having com8 and com9 for the usb dmx pro) or something. It seems to me you don't have to rewrite much code for that.
- remco_k
Re: DMX Universes
Except that people would have troubles with assigned keyboard keys. Although that can be solved by config the both instances right.THW Mark wrote:a nice workaround could be to allow running of two instances simultaneously, both with their own config file. (having com8 and com9 for the usb dmx pro) or something. It seems to me you don't have to rewrite much code for that.
FreeStyler saves some settings in the registry, that needs to be pulled out then.
I agree with Onge, I to know how many time software development takes.
I'm a professional C++ developer myself, so I've been there, done that.
Next to by postings here, I frequently had some e-mail contact with Raph for a list of issues and new functionality in FreeStyler. That resulted in a new beta version wich I'm using now.
Raph decides what he does implement en what he doesn't, he needs to put a priority on each request. Same as I would do when I was the developer of FreeStyler.
Because it is al lot of work to do should never be the reason not to ask it for implementation. Hell, maybe Raph had it on its list already and almost on top, who knows!
To answer Onge's 'questions'.
No, I did'nt (yet) made a donation. I just might going to do that some day. Raph is helping me out alot when I bring up some issues/wishes and bugs, I do the same thing for him by sorting bugs out to the bottom when possible, so he has a reproducable problem without spending hours of trying. He's doing good.
Next to that, if Raph one day decides to ask money for FreeStyler, I'll going to write my own DMX control software and name it TrueFreeStyler.
But, for a few euro's I would stil buy it I guess. But there is a major disadvantage on that: When people need to buy software, they want it to be 100% bugfree. The pressure on Raph is bigger when bugs surface. I know how that feels, and that is not worth a few euro's.
aquas
Re: DMX Universes
I think that only one answear is correct...."if you want more universes, buy an expensive pack", i use Freestyler in my band, and the limit of channels is not so far...so i dicide to decrease the number of channels, so equipment use not 20 but 10 or 12 channels, in six led bars means more six new led bars.
I tell to my boss...you want more? Buy another""...
And another thing i've tried lots of dmx software and the choice is simple... Freestyler because is simple to use, "cheap" include the interface, and powerfull... we can do everything with this software.(Not everything, like "children", but sometimes when we use it, the lights...helps)
cumpr
cumpr
THW Mark
Re: DMX Universes
yup. and people sometimes forget it is not a big issue to use multiple fixtures per channel. For example, i've done some lighting on "mobile" white dancefloors with like 40 parcans and some movingheads. Does anyone care that the red lamp in the lowerright corner burns at the same time as the can in the upper left? Reduces channels from 40 to 20. More channels for your movingheads, as pairing those isn't that handy..aquas wrote:so i dicide to decrease the number of channels, so equipment use not 20 but 10 or 12 channels, in six led bars means more six new led bars.
- djSupport
Re: DMX Universes
Onge yes he ahs missied out the doination button when he updated the site I wonder if he knows that?? I will remind him!
Abraxxus
Re: DMX Universes
i make a donation, if made the second universe and translated Spanish
- djSupport
Re: DMX Universes
You'd need someone spanish to trannslate it into spanish...
aquas
Re: DMX Universes
Some days ago, i thought in translate to Portuguese, it helps but.... my "bad" english isn't enough... not alone, but if i find here someone that help me... you can think to put another language in FS!!! hehe
greats
greats
